I remember reading something about adjusting the cylinder or something in the manual. Because after time it wares and won't go to the right position anymore. I'd check that manual page. Sorry I can't be more helpful,
Dano
Re: unloading auger wont swing all the way in
Uploaded with ImageShack.us
Number 7 is the timer that is installed on the stack valve bracket if you have it, if you have it there will be two black boxes with wire connectors going to them, if it is original it will only have one black box and the number 31A will control the swing in and out on top of your unloading auger pivot, if the timer was installed and didn't take the original switch on the top off it should be unplugged. If you have the switch on top you can unlossen it and turn to see if goes in more.
ram
on my cts combine auger ram, the ram was turned to adjust the travel of the ram which resulted in the bottem end spool inside the ram, unscrewing itself , the proper way to adjust it is by turning the clevis and holding the ram.
