The horizontal swinging auger, the main top bushing, ours has tons of play and is jumping into the cradle when retracting.
Has anyone replaced this? Just want to know if i can do this in a morning by supporting the end of the auger and just lifting the top plate in the grain tank, and swapping the bushing, or if we should wait until after beans if the whole **** auger has to come off (we just did a new inner horiz. auger due to stripped splines), and the vert. auger bearings.)
Also, when these bushings wear, do they take the pin with it (that i guess is probaby built onto the 90* bend of the tube? Dont want to get it torn down for a quick fix if its likely that it needs much more in depth work.
9860 sts, with the large auger. 2100engine hours
