I,ve got a 9500 that the variable speed cylinder sheave will only move with the belt off (like there's not enough pressure with the belt on). I have tried swapping several things around on the valve stack (spools and solenoids). Just curious if the solenoids are not getting full voltage?? I've got 10.8 What is the voltage suppose to be? It has a new hydraulic pump. Any suggestions would be appreciated. Thanks
