Well, this seems to be the forum with the 400 gurus so I had to sign up. There is a serious void on the internet when it comes to these swathers and the 200 ford industrial they use.
I have one that has been converted to a loader. When I got it, the initial timing was set at about 25 degrees. The only information I could find is for the 200 ci 6 cyl used in ford vehicles.
It recommends 6 degrees for a standard and 12 for an automatic.
I set the timing to 12 degrees and it starts and runs fine, but diesels on shutdown sometimes or just pops and seems to be running a little hot.
I am just wondering if anyone has the ignition timing specs for this engine?
Thanks in advance (no pun intended)
