First problem, runs rough when first starting. Take approximately 10 minutes to get it going. Once it is going takes another 5 minutes to inch the throttle up high enough for hydro-stat to engage. It then run great until you have to shut it off them the cycle has to repeat. I have changed the wires, plugs, fuel filter, carb kit, governor, points and condenser. Looking for suggestions
Second problem, double swath header will not move from side to side. Having trouble trying to locate solenoid to see if that is the problem. Any ideas welcome
