Has anyone seen an app or uses rh alarm of any kind instead of setting my alarm every hour to check rh on the phone at the local weather station, when I'm trying to get my hay baled
It'd be pretty tough getting hay baled down your way wouldn't it? I'm up at Hamilton and have gone to doing rolls as both hay and silage cause squares are just too finicky to press.Is it fairly consistent with their forecasted rh
I will go to the field when it gets to 65% and it wont be long before it will be retaining alfalfa leaves. For triticale or wheat straw I will go around 50%.out of curiosity what RH % does it take you to leave the house to go baling? ive generally found ozforcast to be reasonable and the latest weather obsv off BOM give or take an hour or so for good baling conditions.
The bit that s###s me is how much variation there is in RH as we may travel 100km at times. And can be ever way.This year panhandle is spot on I don't get out of bed for any less than 65% rh, in a year with a little more soil moisture than we've got at the moment it's more like 50% rh
