warning lights stopped flashing on my 9600. I have looked thru the part catalog and have not found a flasher unit. Without a tech manual I am at a loss on how the system works. If it is similar to the truck, I would be looking for the flasher unit to replace. Any help is greatly appreciated.
The flasher unit is in the central electronics box outside of the cab door. It is built in the power distribution board, there is a relay that can be replaced, but the flasher unit you can not replace, if bad will have to replace the board. The flasher relay is makered, maybe change a good relay that you know works for that one to see if they work also check the circuit breaker. There is a long list of things to check, see if the other things make it work, if not i can try to tell you were to check for volts.
Thanks for the info. I thought the flasher unit was part of the electronic box. I will move the relays. I also found that the turn signals are inop, so I could have a circuit breaker open.
thanks again for your help
