1 - 11 of 11 Posts
I have a 9610 with the large floatation tires(35.2 30) or whatever is close. My header looks like the guards are pointing at an angle to the ground(down). Do I need a wedge kit to make this a better angle. It doesn't feed good especially going downhill. I think the header should be tilted back but don't know how. Hope someone can help because if the wind blows and the sun comes out it won't be back to the shop until Christmas.
Had the same problem and went to larger rear tires--16.9 X 26 to 18.4 X 30--not only got the header angle right it increased capacity as the walkers and shoe had an up hill angle.
Plus with the 35.5 on front the mudhog was spinning alot when in 2nd gear and bigger rear tires helps this problem.
1 - 11 of 11 Posts
