41 - 48 of 48 Posts
This winter's covid project. 1975 850 versatile.Upgraded to heavier planetaries, split tractor and re pinned. Rebuilt steering cylinders. Removed engine and complete rebuilt. Rebuilt to 335hp. Brand new brake caliper. Bought 2 rear fenders from a wrecker.
New shift tower bottom end....and a complete paint job...well almost....still working on the spacers and duals....found some extra wide spacers so I had to make all new longer dual bolts as well. I fully rebuilt the transmission 3 winters ago as well as the differentials.
Fantastic job, you must of logged on a lot of hours this winter. Where did you find your brake caliber, looking for one for our 846?
Big tractor parts in ND. Brand new brake caliper and different mounting bracket as well as brand new master cylinder. Shipped to my door for $1350CDN
I am pretty happy with the brushgaurd / front weight and potato hiller for the garden tractor. Also built the chicken tractor you can see in the background.
162394
Also RTK auto steer is pretty sweet for cutting the grass
162395
162392
162393
I built the hiller with lots of height if i ever get an old row crop tractor, its also made for a future planter to fit inside the frame. Now for planting I use the ripper to make a line with RTK, then cover them up with the hiller to plant.
Currently building a single row harvester.
Allmasey did you fabricate the tank yourself or use a tank from another cart? Was it tough to connect up all the air lines, meters drives, and monitor system? It looks great.
Cut a 6180 tank in half, transfer the drive from same, set up to singe shui, use cameras to moniter
162400
still welding on the floater frame, had an issue with the gas line on the welder and the feeding motor for the wire at the same time but wanted to get most of it together before we had to move it out of the shop to put the airdrill in. LSW we ordered from them in november are still not in. little frustrated with how long things took to get parts this winter.
41 - 48 of 48 Posts
