I have heard one should be able to find only 1 or 2 kernels of wheat per square foot behind the combine. I have never been able to get my machine (2012 S67 with a Shelbourne XCV 36 stripper header) set anywhere close to that.
It seems like I have a fair amount of shoe loss when I try to push the bushels per hour. I have heard of other Gleaner owners running around 1700 bushels per hour with a similar setup and I've heard of JD S670 owners running at around 2000 bushels per hour with the same head.
Finally instead of spending so much time checking behind my combine, I decided to start checking other peoples fields. I am not seeing anyone with 1 to 2 kernels of wheat in a square foot. I am wondering if when that kind of thing is said, people are checking an area much smaller than 1 square foot?
We drilled on 10" centers so I check between the rows for 14 or 15 inches. When you thoroughly do that, you sure aren't doing it in a single breath as you try to blow the chaff away. I also notice that if I blow hard enough to blow the chaff away I also blow seeds around and they often want to blow downhill towards the rows themselves where it is harder to find them.
For me it's very rare to see less than 10 behind the combine.
For what it's worth, I have the factory rotor with new bars in the concave area. The concaves are in excellent condition as are the helical bars.
I have four factory AGCO cover plates on and I have three extra covers made by my dealer and held on with j-hooks so I would say with the factory covers I have something like 2 or 3 bars covered all the way across the bottom of the concaves and with the dealer covers I have another 3 bars covered on the right three concaves.
I have leveled my concaves with a 1/8" hex wrench as a gauge and I have also calibrated the concaves, fan choke, and chaffer/sieve, but the Lang combine specialist says I leveled the concave 1 bar down from where I was supposed to do it so they are probably running tighter than 1/8 of an inch when I have the concaves set at 0.
I am running the concave at 0 sometimes but I occasionally pull it back to 0.02 or something like that to see if there is a difference in the sample. I have run the rotor RPM between probably 500 and 800
I am running the fan wide open. I have I am running the chaffer most of the way open (22 or so on the EIP) or I start to run some out the back. I am running the sieve at about 8 or I'm getting unthreshed heads in the sample.
I can't seem to get more than 1000 to 1200 bushels per hour out of the machine without getting pretty significant losses.
I did a kill stop (only once) and when I checked the chaffer there was a significantly heavier load on the left side of the chaffer than the right. I was really surprised at how much material was piled up until about halfway back on the chaffer but then I've never looked in a combine before after a kill stop.
I have neighbors with competitive machines (JD S670) running faster than me with the same header (around 2000 bushels per hour) and they're feeling comfortable with their losses.
I'm just trying to figure out what I should be doing and what I should be able to expect in wheat for combine loss (after header loss is subtracted out because there definitely is header loss with a Shelbourne)
Any thoughts would be very much appreciated. Thanks.
