Too much! Although I think Viterra...CPS maybe is getting rid of some of this equipment they used to carry so there may be discounts?What are they worth?
Your rims have one single hole in them? Ours guardian does. Just make a spear that mounts on your pallet forks Works like a dam. Sorry I can't take credit for the idea thoToo much! Although I think Viterra...CPS maybe is getting rid of some of this equipment they used to carry so there may be discounts?
I had a patriot and could just spin the rim on the hub once we put it on there with the telehandler, worked great! Took under an hour to do all 4 tires. Now have this NH front boom and just studs...no hub.
Is there any good way to rotate the rim to line things up or does one have to build or buy one of these?
Excellent thanks! I suppose the only concern is that it doesn't slide off the end, maybe make a flange so it stays near the end though?Your rims have one single hole in them? Ours guardian does. Just make a spear that mounts on your pallet forks Works like a dam. Sorry I can't take credit for the idea tho
It never has been an issue our pallet forks are on loader so just tilt it up a bit. Make sure your hole is always at twelve o clock and your studs will line up pretty closeExcellent thanks! I suppose the only concern is that it doesn't slide off the end, maybe make a flange so it stays near the end though?
