I had to repair/replace 2 rubbed through camera cables in the air drill I bought. They were inside a loom with 7 camera cables inside. I put new cables in to replace the old. They were tied into a Deutz connector at the rear of the tractor and I had to cut off the "shrink tubing". It was stuck on so well that I literally had to cut it loose from the wires and did pull some of the wire insulation off with it on one occasion as it is stuck on so well.
It was so durable that it added a huge amount of strength to the connection. Camera wire was like 22 gauge and attached to a 16 gauge wire. It made a very rigid joint and appeared to be melted together to the extreme!
I have looked on Amazon and I don't know what this product is called. Would it be a really durable heat shrink with an adhesive in it so that when it melted, it turned solid? It is an amazing product and I wish to purchase it for future fixes. There are always issues when hooking fine wires to coarse wires as you don't want the wires to be the strength of the connector.
