1 - 9 of 9 Posts
Be cautious!!!
We also had some very wet years...look at the gallery:
Ernteschlacht im Nordosten | Arcus | Agrartechnik-im-Einsatz.de
or this... (not that heavy)
Ernte in MV Gro?betrieb Teil IV - Schlammspiele 2007 | Arcus | Agrartechnik-im-Einsatz.de
Preview:
And we destroyed a lot at our combines by pulling them out!
Examples:
We hooked it to the header, pulled, and ripped the header off... and riped off the whole wiring harness from the main CPU...
Also dont use the hitch of the header trailer!...you either rip the hitch off,or the whole rear axle! Depends how deep you are stuck...
We also demolished the fan casting and the feeder house several times.
The best is you dig a bit and hook your rope to the front axle.Then pull forward!
I have never been stuck with our tracked Lexion combines. The last wheeled combine we've had stuck we hooked onto the main axle, we've also hooked onto the hitch with which we tow the header carrier, that being said you have to use common sense when pulling out anything stuck, use ropes instead of cables or chains. Good luck
1 - 9 of 9 Posts
