What are you guys using for hauling your draper heads that you use on your swathers? We have a 35' D60 that we haul around with our current header cart (Duo Lift) and it works fine but the swather (M200 MacDon) won't lift it high enough to put it on the cart due to the design of the cart. The combine has no problem lifting high enough but the swather won't quite do it. So, what are people using that is low enough for the swather to put the head on?
Thanks
Thanks
