Inversion risk would be at a minimum.I've sprayed in 80KPH winds
Oh I agree, but the green on their scale says 20kph but it’s in reality only green when it’s around 30 and gusting much higher. Basically I can look at their maps and forecast and if it’s a brighter green I’m pretty confident that we won’t be able to go. Of course we’ll go and check anyway but it’s pretty handy for planning and getting an idea of when you will be able to go. Seems pretty accurate, once you understand that the green on their scale is actually much higher than it says.20 KPH is pretty much ideal for spraying flat ground but too much for rolly ground.
It was not my call. There was no chance of damaging another field but I was also concerned about misses. The customer said do it anyway and we will see (pre-seed). It did a perfect job. I had no issues getting chem on the field (I run my booms LOW, 20-24 inches) but did have issues getting chem in the sprayer. I don't use a handler with a spike so I open and pour each jug and the wind would blow the chem all over the place while trying to pour it in. Also, I couldn't keep the the boxes and jugs from blowing away. A buddy that runs a floater had to shut down just kitty corner form me as the wind was blowing the fert all over the place. There were shingles lost and bins blown over than day.I have a hard time believing the 80km. Can't keep a hat on in that let alone chemical on the field. Maybe did no damage to the next field but can't believe the chemical would touch the ground in the field you were spraying.
I can never figure how this site works either!OK, stupid question of the day.....how do you use this site??? I click on it and it comes up with a small window in the corner of local weather but I don't see wind on there.
