I'm looking at a 9860 JD - 1100 sep hours, came from Pasco WA area. No idea what kinds of crops it's harvested.
I paid for a service inspection before agreeing to buy it - here's what they said. Please keep in mind this is my first rotor machine, so I'm not sure what to think. No, I haven't put a set of eyes on it yet, as it's 400 miles from home, but I am TRYING to make an effort to get to it.
As follows -
- Chaffer & sieve….will not open or close.
Shield is missing rubber strap.
Tilt Frame: Missing bolt, left side fore/aft
Feederhouse drive chain needs adjusting.
Reverser oil is low and has a leak.
Feederhouse drive belt needs adjusting.
Cam arm bearing needs inside bearing.(cleaning fan)
Clean grain elev. Upper idler bearing is out.
Discharge beater speed sensor missing hardware.
Fuel separator bowl needs clean out.
Fire extinguisher is missing.
Antifreeze level low.
Engine air filters, need replacing.
Hydraulic oil leak, weld on top of tank is leaking.
Union leaks on dual range shift.
Discharge beater strips, missing 3.
Chopper, bottom tin at stationary knives needs repair.
Primary gearcase leaks at input yoke.
Gears have wear on shoe augers.
Unloading auger shear bolts are missing.
Sieve wiring is missing a plug.
2 wing lights are out.
Trans. Oil level is low.
Final drive on LH side is low and leaking.
Inner drive wheels have been welded.
Cab filters should be replaced.
Left side rear taillight is out.
The sieve and Chaffer are supposed to be replaced new, and are touchset.
Thanks for any thoughts and comments -
As follows -
