1 - 1 of 1 Posts
When I'm going up a steep hill the grain pan under the straw walkers fills with grain and trash and it will not slide forward onto the grain pan/sieves,then when you level off the whole lot slides forward and over loads the sieves and goes out the back.
I have put the axal in the bottom hole.
I think the pan needs ridges like a normal grain pan to push the grain back when going up a steep hill as the pan is level or you may even be trying to move the grain against gravity.
Other than going up hill it works fine,this is a new machine and all that JD UK say is to polish the pan under the walkers but I can't see this is the cure.
Any advice, many thanks Dalers
1 - 1 of 1 Posts
