I have a 2009 CASE-IH 9120 combine that when the weather gets below 55 degrees the yield monitor will not work, it says that the connections failed, I had my local dealer work on this several times last year and they thought I was crazy when I told them it worked on warm days but wouldn't when it cooled off. (Usually they thought they had fixed it but actually it had warmed up and the sun shining on it made it work) I finally proved this by taking a hair dryer and blowing warm air on the sensor for about 10 minutes one night and after doing so it worked fine until I shut combine off and went to dump a truck load then when I came back it was same thing AFS 600 monitor would say no connection to yield monitor. Also my moisture sensor keeps blowing the in-line fuse, my local dealer put a 10 amp fuse in and it still blew fuse, motor seems to be fine because when I took it off and hooked it straight to 12 volt supply it ran fine. Any ideas would be appreciated.
