I have an older YM, which I call the "Black Box" which has the 2 line display function. IH version 6.02
I tried harvesting corn and when you start a new field the next question is select crop type.
Here is the problem. To select the crop type the bottom line shows like a bar graph half way across the screen. What should I do? I cannot see the name of the crop ei. corn,beans,oats Thanks.
Also, if moisture shows 5.0% all of the time, I have read that the moisture sensor has a poor ground. If this is so will Bush.per acre calculate anything? Showed 0.0 Thank you.
likely a bad internal battery in the display. You can order a replacement from your CIH dealer or from a battery retailer. IIRC it's a 3.2v battery. You can open the display and check it out yourself.
