My 2010 CR9040 monitor frequently shows the error "yield sensor out of tare range". Most times it also shows "grain moisture sensor power source disconnected". Both moisture tester and yield sensor seem to be working, however I think the yield sensor could be more accurate. I have done a few yield calibrations. I read somewhere that NH had an issue with the yield sensor mechanism and there is no fixxing the problem other than to replace the entire yield sensor. But in the conversation I read the guys were discussing machines quite a few years older than mine so I'm not sure it the problem with my rig is the same as the combine they were debating about. Any insight on this would be appreciated.
