1 - 9 of 9 Posts
I've been there ones and asked the guys why not cut the trees down, he said fines would be severe, still nobody talked about "running" into them. such a waiste just cut the tree and replant 2 somewhere else
What kind of power does that tractor have? I would imagine the cart fans run off engines or that would be a long way to pump hydraulic oil of any volume.
It has a KTA 1150 Cummins @ 600 h.p, and an Allison auto. It weighs in at 70,000 lbs.
Here`s a close-up of the actual tractor in the O.P.`s video.
It operates on a property not far from here:
https://s-media-cache-ak0.pinimg.com/736x/11/c4/55/11c45548a265357b7aef8f080fa35b34.jpg
http://www.redpowermagazine.com/forums/uploads/monthly_11_2012/post-2338-0-10333200-1352452516.jpg
Row spacing is usually 15-20 inches in that area.
Planting depth anywhere from 2-6 inches below ground level, depending on how deep moisture is.
Normally single shoot with low rates of starter fertilizer. N is either pre-drilled or not used, depending on how newly developed the land is:
Here`s another one of their sowing rigs:
1 - 9 of 9 Posts
