Casein mxm 130. Everything was running as it should. Had to shut the tractor off to check on a hydraulic line. Fired it back up and as soon as I did the snail symbol appeared, and I lost my high speed gears. Not a fuse, I have power at the high low switch.
As far as I can tell with the tester, my relays all have power.
the solenoids under the cab seem to be working. All right, kicking in and out and such, when the switch is cycled.
has this happened to anyone before? And if so, how did you remedy it?
i have all of A range gearss, B range gears and only C1. I have nothing above C1
