Tips for getting top corn quality out of STS combines
1 reading
26K views 19 replies 10 participants last post by  johndeere95
#1 · (Edited)
These are our findings that will significantly reduce fines in all STS combines that include all 9X50, 9X60 and 9X70's.
The problem with fines is that they are generally created before the corn even gets to the rotor on these machines.
Setting the accelerator on slow speed will not be enough.
To get the best results:
- use feeder house drive sprocket # AXE10874 and run the 15 tooth drive
- put swept back paddles (H201914) on the feed accelerator (use these for all crops...corn, wheat, beans)
- these are used on ALL STS combines right up to the new series
- run FA on low speed
- run the front feeder house drum locked in the 'up' postition
- use round bar concaves with no inserts or covers
The slow speed feeder house drive and swept back paddles WILL solve the vast majority of fines in most cases.
The reason that all the other settings are not helping is the fines are there before the crop gets to the rotor.
Running an STS with these parts will give you the best sample possible of any colour combine in our experience.
Getting samples down to 0.2% dockage is very achievable
Another MUST have in high yielding corn is louver restricters, PN H221769, you will need 3 and they cost about $25 each.
They keep corn from running into the fan when you are running a lot of bu/hr through the machine.
#2 ·
Sounds like quite a process. I never realized how much you have to do to one to pick corn.
The brand I run requires :
Putting the feeder house drive in slow range
Shifting the rotor gear box to slow range
Putting the feederhouse down stop in the corn position
Put chopper in slow range.....and drive.
#3 · (Edited)
You do this ONCE...when you buy it...after that it takes 5 minutes to change from crop to crop.
How long does it take you to go from corn to wheat?
It takes us less than 15 minutes.
I have seen lots of tips on every other brand to get perfection out of a machine...did not know one existed where this was not the case.
What brand is this?
Please educate us.
So there is nothing you would do to your machine combining 30% corn?
Out of the box is optimal?
No parts to change or add?
#4 ·
Ground Feed HELP!
We finally got corn from going out the back end of our S670 after buying the C&M Welding replacement concaves and disrupter lugs. Wow rotor loss dropped off completely. Now we need to clean up our sample! We already took off half of the feed acc. paddles, maybe if we took all of them off?? Heard about the slow down kit but $1700 I don't think so. We slowed the rotor all the way down to 240 rpm, can you run it too slow? Is the corn bunching up between the accelerator and the rotor causing the cracked grain?
Any more advise would help.
#6 ·
You need to install the swept back paddles so the corn is not hitting a square edge when it enters the FA.
Also...cheap and easy...slow down the feeder house to a crawl. It does not need to go fast at all in corn.
Just talked to a guy wit a 9770 that installed the sprocket that I mentioned in the first post and he noticed a big difference in fines.
You are not getting any damage in the rotor...or very little.
#12 · (Edited)
Kinzeman what are you smoking, crack corn pipe? I've been getting tired of reading this bs on a few different forums I read. It is impossible to set up a new Deere combine out of the factory to do a high quality job in high moisture corn. The Deere engineers can't even do it!!! The amount of grain damage is not acceptable as a farmer/elevator owner. Sorry if I offended anyone with this but it is the stone cold truth. The fines coming out of the machines are not the problem it's all the damaged kernels. Have you ever done a cracked/damaged kernal count?
#13 · (Edited)
Have you ran an STS with these small changes?
I have has several calls from people who have done these simple changes and thanked me because it made such a difference.
But...yea...I guess you know best...please keep up the great work!!!!
A name of corngrinder with one post...hmmmm
Oh...just because it ticks you off...I am going to keep posting this everywhere.
Where do you live...maybe I will take out a billboard just for you.
Idiot...
So corngrinder...what do you have for a combine?
#14 ·
Well said KINZEPOWER!!! I too have had customers say how satisfied they are with the improvment.
Idiot...
#18 ·
I agree set up set up set up.how can any manufacturer build a combine that will work in all conditions. I know in eastern Ontario none of the suggested settings have been right on. We always close the concave a little more. Another problem is the operator wants to switch between crops in 1 minute. Even taking the head off is a pain in the --- . Let alone having to move belts and lift the drum. I will often give suggestions to improve a sample or check for losses and the response is "do I really have to do that " so most of the time I don't feel sorry about the results.
This post has been deleted
#20 ·
I guess I must just make it all up, I'd love to have a deere combine always have had one, I'm the guy that has old Johnny poppers and 4020's and old combines and all kinds of neat old jd stuff, so I'd say I'm a "John deere" guy, I guess I must have made it all up to consider switching colors after running green combines since 1966.
