2366 AHHC Potentiometer + Header calibration
11K views 5 replies 3 participants last post by  michfarmer
#1 ·
Hey all,
We have a new to us 2366 and I'm currently getting it set up for wheat. I want to use the return to cut feature and I guess in order for it to work properly the Potentiometer cannot be plugged in. Is the only way to disconnect it to unplug that wiring harness from the feeder house or is there a better way? Also, I do seem to be able to calibrate header control properly. I can't cycle through the Standard/auto height/float options (0,1, and 2) I can only select 2 and then when I get to the step that says "dn" and I turn the height knob fully clockwise it doesn't progress any farther when told to. If you guys have any points or help that would be great!
Thanks,
Jon
#3 ·
Yeah we have AFS. I had everything connected when I was trying to calibrate it but maybe the connection was not actually being made... I'll check the pots. Those are the things on each side of the feeder? When I tried to use the return to cut with the one wire harness (the top one) plugged in it would lower but then come right back up. When I unplugged the harness it would go down to whatever height I had the dial at. But I'd get the header error light on.
