You will have to remove the long belt on the right side that drives the cross shaft, then remove the cross shaft that drives the augers. Set everything out as it comes off, I find it handy to take a picture on cell phone, for reassembly. Chances are you will have to torch some or all the bearings out, so open the hinged door below the augers & clean the pan out to reduce risk of fire when cutting. Then i always use anti-seize when reassembling. Take a good look at the bevel gears for wear as well as keyways in the cross shaft, & replace if necessary. I think the gears are held on the augers with roll pins. Then clean behind the bearings every year after you're done.
