9240 Case combine won't go into gear
1 reading
2.3K views 15 replies 8 participants last post by  bad altitude
#1 ·
Drove the combine into the shop a few days ago and everything was fine. Started it up today and it won't go into gear. Keeps telling shift incomplete go back to previous gear. Checked fuse is ok. Anyone have this experience before? Any ideas appreciated.
#8 ·
Can’t see any evidence of harness rubbing anywhere. Did pull the servo shift motor and it turns when battery power supplied. There is a gear position indicator/sensor up there as well. According to that the trans was half way between neutral and second. I got it to neutral by turning the big nut under the servo motor that LTO referenced above. Reinstalled motor and still nothing. Beginning to wondering if it’s not that sensor.
