Anyone know what it takes to change the pto shaft on a JD 4955? Powershift transmission with MFWD.
We have one that's bent so badly the oil leaks right out and we can't even run it without using the PTO. We were pulling a heavy disk and somehow the clevis bolted to the top of the drawbar broke off and disk tongue popped up (and forward????) and smacked the pto shaft.
Anyway we're wondering if we have to split the tractor to replace this shaft. So far we've put a bar behind the plate that holds the shaft in and cannot budge it. The bearing carrier there at the back is also cracked, but that comes out the back.
