Went to get the 900 ready for the season and when trying to sharpen the knives I got several error codes. They were e62,63,64,66 and e68. I checked all of the fuses on the machine and all were good. According to what I read these codes are saying lack of power to the module, module failure, or can bus error. The only time I got them to come up was sharpening. I was able to run the feed rolls in reverse and forward. Tested the metal alert and it worked. Everything else seems to be working normal. Could it be something in the sharpening module shorting out the system or maybe something in the feed roll harness as I've noticed they need to be plugged into the machine in order to sharpen. I looked under the fuse panel and didn't see any mouse damage and also checked that the sharpening module was plugged in securely. Any other ideas would be greatly appreciated.
