s660
1 reading
8.3K views 8 replies 7 participants last post by  bundaleer
#1 · (Edited)
looking for capacity outa a new s660! 35ft draper, reaping 2-2.5 t/ha feed barley. loosing grain of the rotor, any tips or settings would be muchly appriciated! dealer told us to 'drive it like you stole it' but grain loss was huge!
#8 ·
What settings are you running now? Shouldn't be losing any barley going under a ton to the acre. I'd second the advice of running a large wire concave in the rear but need to know where you are at now with rotor speed, concave clearance and operating speed
#9 ·
thanks again. we had the concave to tight and rotor not fast enough, i think we were nursing it a bit! the jd tech just opened everything up and ran the rotor as fast as he could. A little tip if anyone cares if put your machine in gear then step the revs up you gain about 100 more rotor revs, as opposed from going straight from idle to full noise! every little bit helps. We descussed the large wire concaves and that is our next step to get anymore capacity if we need!
