*250 series hydraulic noise.
1 reading
1.4K views 6 replies 5 participants last post by  rod
#1 ·
Have a ‘21 manufactured 7250 that makes a high pitched whining noise/ vibration when the hydraulic pump strokes up.
It’s very noticeable when the machine is cold and I turn the steering wheel. It’s like a vibration in the steel line that comes forward from the valve block to the hand metering unit under the cab. I thought it was possibly a relief valve opening and the noise travelling along the line.
Does get quieter once it’s warm but it’s still there. Makes for a long day listening to it.
Dealer has checked all the steering pressures and they were fine.
Just wondering if others have experienced the same noise?
#3 ·
Both our 8250s have the same sound that seems to often start right as soon as you crank the engine (before it's even running). It's a subtle sound but noticeable. I don't hear it at all while running at full throttle. Sometimes I notice it while cooling the machines off at the end of the day. Does seem to be hydraulic because as you say steering will change it.
#5 ·
Yes that’s the one. Starts as soon as you crank.
It’s only faint when at working speeds but it’s like a little tune playing in your head all day. . . . Or maybe it is🤪🥴!!
Good to know that that’s just how they are. Now I can just sit back, relax and . . .wait for the transmission input coupling and shaft to fail 🤦‍♂️
