Canola header dilema
18K views 33 replies 15 participants last post by  Highmarker
#1 ·
I have a question for the folks who grow a lot of canola, what kind of headers do you guys use? Here is my dilema, I farm in Eastern Washington State, which is a predominantly wheat growing area (with some barley and triticale). We started growing some canola a few years ago and with wheat prices where they are these days we are going to be putting a lot more canola in this spring. Thus far I've been cutting it with an older HoneyBee SP36 draper, but I'm not real happy with the job it does with canola. I have a top auger on it, but this header has a split reel and the canola tends to get hung up on the center support, and the header just doesn't feed real well in general. I also feel like that header has a ton of holes and gaps that canola is getting tossed out of as well. Yields so far have been around 35 bu or less, but I'm hoping to improve upon that significantly.
I purchased a Shelbourne stripper header a couple years ago which I LOVE for harvesting small grains. I would really like to use it on canola too, and I'll probably give it a shot, but I'm not terribly optimistic that I'll get satisfactory results. To further complicate things we also are beginning to grow some peas and garbanzos. At this point I think the best thing to do would be to get rid of the Honeybee and get something more appropriate for these other crops, but what is going to be the best choice? Canola and legumes are all very new crops to my area so the usual practice of copying what the neighbors do isn't going to work.
Right now I'm leaning towards getting a flex head with a full fingered auger, something like a Case 3020 (even these are very hard to come by in my area). If I can find one I hope to rent it for the season and then make a decision after harvest. I think the best thing would be a header with the extendable cutter bar (like the Claas Vario or Biso Ultralight), but there isn't one of those things within a 1,000 miles of me. What insight can you folks give me?
#2 ·
Are you straight-cutting? What type of combine?
Probably good to note that with canola it's best to cut into and with the lean, unless you have a header with the shears on the dividers. Usually a guy figures out which direction is best after the first couple of rounds though...
#3 ·
We had a field this year we couldnt even make a headland so bad, needed a crossauger but took it off anyway, talking about eating the steering wheel, still like swathing canola when it goes smooth, dont care for the swathing at night part
Lots of very cheap staight cut haders to be found in manitoba and sask since every tom and hank is switching to flex heads
#15 ·
We also farm in the Eastern Washington (Palouse) area... We harvest SW, WW, Peas, Lentils, Canola and Barley using the MacDon drapper flex heads. We are running the older series, don't remember the name right off the bat, but the Case IH number is 2062 (36 foot drapper flex), mounted on Gleaner combines. One of the headers has the top auger, the other does not. We have used both in the canola, but the top auger is a BIG advantage (in grains, not so much). We try to only use that header in our canola if we can. We also installed a hole punched sieve in the combine, instead of the adjustable one for cutting the canola, made the seed in the bulktank lots cleaner.
#16 · (Edited)
With the draper headers, a cross auger (pea auger) is pretty much required, in our experience. My cousin tried canola with his honeybee without the cross auger and it wouldn't feed well at all when the canola pushed against the back of the header. Dry canola is a lot fluffier than canola at swathing time.
By the way if you get a Macdon draper, you might want to buy the small seed saver kit for it. It consists of some rubber flaps to seal the edge of the side drapers better against the center draper. Plugs some of the gaps where seeds might be lost.
#23 ·
I would go with an auger flex. I think it's the best bang for you buck and the most versatile. We have a 630R, 630D, 630F and a 635F. We have demoed 635FD's and 640Fd's and were really impressed with them but they are just to high in price for our operation when there is other alternatives. Since we are growing more soybeans and straight cutting canola more now the auger flex fits the bill pretty well and they are cheap compared to a draper. I actually think they do a better job straight cutting canola then a draper and I have used both before. More places for canola seeds to run onto the ground with a draper. Then you also need a cross auger for sure to on the draper. I have also had problems with the drive rollers gumming up and canvasses slipping from crushed canola seed. This year we used our 3 auger headers to cut the canola with and it was the best experience we have ever had straight cutting canola compared to when we tried with our drapers in past years. Now our 630D is kind of the black sheep in the yard as the only thing it's good for is cutting wheat and hopefully our acres will be dwindling in that respect.
