How cool is this? Can’t wait to see one.
The electronics right at the valve stack liked to fail and there was an oring on the coupler cartridge that failed too. Must push a bit more pressure than the JD’s because they hardly had any trouble with the same valve but their own electronics.What were issues with those hyd valves ?
Isnt the whole point of these tractors to be basic without all the bells and whistles that the current crop of machines have and that make them so unreliable. In my experience the worst failure point is electronic hydraulic valves. On my blue Steiger 3 of the four failed, 2 JCB's they all failed. My brothers Magnum 1 of 3 failed, the JCB he bought new has 1 of 4 left working after 5 years. If your going to insist on not connecting a lever to the valve stack then just have bang/bang valves that are at least reliable. The proportioning valves on Ag tractors are basically a gold mine for dealer service depts.The electronics right at the valve stack liked to fail and there was an oring on the coupler cartridge that failed too. Must push a bit more pressure than the JD’s because they hardly had any trouble with the same valve but their own electronics.
Not his choice. Cut one down go directly to Jail, do not pass start. In one state they'll even charge you if you cut down a dead treeBig fields but trees...
Very practical if you have 1000ha+ fields to seed in a short window.Here's a big bud esque (baldwin) vesion:
Doesn't look like a very practical seeding rig to me. Neat though. Definitely would require section control!
Yes I'm aware of that. I just question whether the 214ft air seeder is actually practical for such fields, as large as they are. Seems to me that all of the efficiency gain of the big seeder is completely lost having to turn around the trees like that. At least on the fields shown in the video.Not his choice. Cut one down go directly to Jail, do not pass start. In one state they'll even charge you if you cut down a dead tree
It does! If you call 107’ section a section.Definitely would require section control!
Well…the unit is about 3+ times wider and ground speed appears to be roughly a wash to our seeding speeds but compared to my area seed rates and especially fertilizer rates would be way, way under 1/3 of my area application rates so with two tanks that look like old Concords one would run quite a while.I suspect you'd spend more time filing than planting.
