41 - 60 of 222 Posts
I haven’t heard any pricing.
Sklexion, have you tried cutting any pulses with the buddy wheels? Says you can cut 1” off ground with them now ?
Discussion starter · #43 ·
No. I haven’t. Lentils are to short. Header needs to be on ground for the red lentils we grow. It would probably work for peas. Maybe not this year.
To avoid confusion, the hydraulic wheels come up high enough now that even at a MacDon “A” tilt setting the cutterbar will be right on the ground, even with skid plates all the way up (shortest cut). And they can be set to cut up to 18” high.
Sure I’m not the only one but an early one to tell them it had to be that way.
Original Contour Buddies, the fixed mechanical ones, have to be removed to run flat table/cutterbar on ground.
Sklexion, I can quickly tell I won’t miss that center arm trash collector!
Looks great especially in shorter lentils. Over 5mph on the ground gets scary, lots going on.
So which guards do you have ? And why? Pros and cons to either ?
I can answer for plugfree, guards are not touched on section change, oval shaped bolts fall out when nuts removed but sure that’s the same for both.
Then section can just be pulled straight out.
Knife overlap on double knives a much cleaner setup now.
Sklexion can fill in on standard guards I guess they call it. Plus he’s actually used it.
Discussion starter · #51 ·
Huh, 24% engine power, takes more fuel to run down the road!
Yes lentils don’t take much load. That’s why I like 50ft. Really increases productivity. Nice thing about Claas is it doesn’t take much fuel when it’s not working. Pretty close to two days on a tank.
Discussion starter · #52 · (Edited)
We have pointed guards. Can change sections without removing guards. The fitted bolts make it easy. You may have to move knife a bit. Happy with the pointed guards. We have them because the Macdon rep brought it that way and feels they are better in rocks.
So can we put these style guards on fd1?
Discussion starter · #59 ·
What is oval, the two bolts that hold the section? Do the bolts break or section if something is hit, typically?
Yes the two bolts that hold section. The oval part fits in knife bar. Kinda like a carriage bolt. Bolts will break or section. Depends what hits it. Typically bolts shear
Yes, bolts and holes they go in are oval and are just a comfortable fit.
Too early to tell, just breaking the bolts off sounds labor saving on the replacement! Doubt one could be that lucky.
