I am reviving this old thread on Cat TA-22 ps transmissions to maybe clear up some questions as to what oil to use in them which seems to vary greatly, even from Agco. If what I am finding regarding Agco’s 821XL oil for the TA-22 is true, it could be at the root of an alarming number of failures. I realize this is a very complex topic with every oil supplier and retailer quick to recommend their oil as a superior product. But there are few oils that meet the Cat specs for the TA-22 transmission. Cat stopped selling and recommending their old TO-2 spec oil in 1990. It was just a glorified straight grade motor oil of the day for hydraulic systems. That is the spec of most hytran type oils even today, including Agco 821XL as per Nebraska test which lists this as the right oil. Does anyone else have suggestions of what Agco calls for in this transmission? To make matters worse, many oil supplyers have followed the trend to multigrade oils which is absolutely against the Cat TDTO and newer TO-4 specs. Although Cat does have a TDTO-TMS multigrade for extreme temp range. But looking further into what Versatile uses as a factory fill on their TA-22s in the big tractor line, it is Shell DonaxTD which is a straight grade replacement for Cats TO-4. Maybe that is why Versatile is not having transmission problems? Cat TO-4 (TDTO) oil is said to have additives that significantly reduce gear wear compared to TO-2 spec oils. It could be the .127% zinc in TO-4 oils. I have only found a few oils that meet the Cat TDTO 10W and TO-4 specs. As mentioned the Versatile factory fill Shell Donax TD, Shell Spirax S3, Hytran Ultra, Q8 TO-4 fluid 10W, Allison C-4 and C-3, and a major transmission rebuilder that recommends Mobil HD30 and no multigrades ( I can’t find that one in the TO-4 list). In the Cat world multigrade oils are not used except in extreme cold situations because multigrades do not have the molecular shear strength of straight grade oils. This is very important in a high load transmission environment. Check out Caterpillar Service Publication SEBU 6250 (Cat machine fluid recommendations). P 17-18. I will try to post that segment after I post this.
