This “9250” was hauled in under wraps, 60 miles west of Minot ND yesterday. It needs 2 service trucks to keep it running apparently.
Not necessarily with autonomous machines. Fleets of smaller can be more economical. Lots of small robots essentially.But larger is better so there is no need for smaller combines.
I don't know if we're ready to show them off yet at any farm shows. I could be wrong though. It'll be a twin rotor.Hello, will the NexGen combine be presented at the Farm Progress Show 2023? and would it have a single rotor? or did I understand wrong.
thanks for your answer....everything points to being a beastI don't know if we're ready to show them off yet at any farm shows. I could be wrong though. It'll be a twin rotor.
That sounds awesome Rod. However in some parts of the Prairie Provinces. you are lucky to get in a 7-8 hour day. things are simply too wet to shove through. even @ 700 hpBigger, bigger, bigger, more HP …… 🤷🏻♂️ ……. Plenty of my farming friends & especially professional contract harvesters (cutters) are all questioning this race for “bigger & more HP”.
Why?
Have we honestly reached the limit in capacity & field efficiency of the current class 8, 9 & 10 machines?
I‘d say not. Well, I know not. Because there’s always improvements in the machine capacity to be obtained. Be it from different concaves, rotor bars & or wider cutting widths, coupled with better feeding drapers.
Once youve exhausted that avenue, what about maximising in field & off field grain handling capacity & efficiency?
What about running the machine(s) longer hours per day? If you’re running the machine 12hrs per day ……. adding another 20% to that is only 14.5hrs per day. 15hrs + 20% is 18hrs per day etc. etc. Run 2 shifts on the machine ……. 20% more grain per day is nothing to be sneezed at …… from the same machine!
These new Mega machines don’t come with a friendly price tag either. $1.3m - $1.7m I expect would be the range. Possibly even more.
Many people are already bucking at the asking price for the current 8, 9, 10 sized machines. Professional harvesters can’t get a return on investment now. Where’s the incentive to invest in bigger, much more expensive depreciating steel?
So, interesting times ahead.
