This “9250” was hauled in under wraps, 60 miles west of Minot ND yesterday. It needs 2 service trucks to keep it running apparently.
I took that hump part out. It’s sitting in the corner of my shop. Chaff loads Looks pretty even by the time it gets to the end of the pan without it.Been a long time since I looked inside a CR, but don't the CRs have a grain pan that's peaked up in the middle and sloped towards the outsides of the combine to help even out the mat as it's shaking back towards the sieves?
Ooof, with that wet dream issue, you got MSB…wow that’s I wet dream I have never had, and Iam running wide body chassis sieves
I’m not so sure about the 100kg/bar claim. Adjusting the sensitivity would surely change that.There is also a major flaw in the display of the flagship in that one bar one the graph is 100kg/ha on the rotor loss and 10kg/ha on the sieves.
When drivers see the sieves at three bars and the rotor at one they believe they have high sieve loss, when most of the loss is in fact rotor.
Get the rotor (speed , clearance and separation) correct and everything behind it falls into place
CVT driven rotors is a benefit. DFR synced to rotor speed is another. Concave setup similar to flagship Case is another. Massive air cooling package. 20,000 lt grain tank.Will be interesting to see what they’ve got inside there….. always imagined simply taking the good features from both the CR’s and flagships and putting into one machine would be a great start.
Then maybe putting a concave under a modified rock beater…. That wouldn’t take much and be worthwhile I believe.
…… pretty sure it’ll put someone’s nuts in a tank!Chew the antlers off maybe but will it put the nuts in the tank ?
Correct, this is a on default settings, if you lower the sieve sensitivity to 28 and raise the rotor sensitivity to 58, IIRC, you will see the rotor loss first and adjust things to suit.I’m not so sure about the 100kg/bar claim. Adjusting the sensitivity would surely change that.
Help me understand this please!Everyone has probably seen these by now. Looks like a dealer release show in Europe just recently. So the “Bi-axial”might be running sooner than we thought …….or mostly likely, sooner than we all guessed!
I guess we'll see, certainly going to be interesting! sounds like Case IH has a beast in the works! Exciting times for a combine loving man! Lololol. I caught wind from another web source today that John Deere may be working on a bigger X9 as well. Not sure if any physically bigger, but I assume performance wise, because I've heard a 1300, and a 1400.Don’t know …… for all of them. From memory, 8250 max HP is 550 or thereabouts. 9250 max HP is 630 or thereabouts. Maybe they’ve increased HP on the 60 series range …… but I’ve really no idea.
From my understanding, the Bi-axial model(s) will go from just over 700 HP to 900 HP or thereabouts. I’ve heard a claim of 1,000 HP for the biggest …… but I expect that to be in someones imagination.
I guess we’ll all find out the real details in the near future.
Bigger, bigger, bigger, more HP …… 🤷🏻♂️ ……. Plenty of my farming friends & especially professional contract harvesters (cutters) are all questioning this race for “bigger & more HP”.I guess we'll see, certainly going to be interesting! sounds like Case IH has a beast in the works! Exciting times for a combine loving man! Lololol. I caught wind from another web source today that John Deere may be working on a bigger X9 as well. Not sure if any physically bigger, but I assume performance wise, because I've heard a 1300, and a 1400.
Your right, the bigger machines are definitely appealing to the folks looking to cut number of machines due to not being able to get the adequate number of qualified employee's. Finding the needed employee's is a big concern these days and the bigger machines can help with fulfilling the needed productivity with less crew.For some guys, finding people qualified to run the combines is very difficult. So for them the bin twin rotors might be appealing. If you can get decent guys or gals to run the combines, the cost of labor isn't high enough to warrant the move otherwise.
No return on investment is the end.Bigger, bigger, bigger, more HP …… 🤷🏻♂️ ……. Plenty of my farming friends & especially professional contract harvesters (cutters) are all questioning this race for “bigger & more HP”.
Why?
Have we honestly reached the limit in capacity & field efficiency of the current class 8, 9 & 10 machines?
I‘d say not. Well, I know not. Because there’s always improvements in the machine capacity to be obtained. Be it from different concaves, rotor bars & or wider cutting widths, coupled with better feeding drapers.
Once youve exhausted that avenue, what about maximising in field & off field grain handling capacity & efficiency?
What about running the machine(s) longer hours per day? If you’re running the machine 12hrs per day ……. adding another 20% to that is only 14.5hrs per day. 15hrs + 20% is 18hrs per day etc. etc. Run 2 shifts on the machine ……. 20% more grain per day is nothing to be sneezed at …… from the same machine!
These new Mega machines don’t come with a friendly price tag either. $1.3m - $1.7m I expect would be the range. Possibly even more.
Many people are already bucking at the asking price for the current 8, 9, 10 sized machines. Professional harvesters can’t get a return on investment now. Where’s the incentive to invest in bigger, much more expensive depreciating steel?
So, interesting times ahead.
I can't wait to learn more. Seen on that picture of the next generation that the horsepower on the low side said 700, can't wait to see what the top horsepower will be??? I think they definitely have a beast in the works. I've also caught talk of John Deere working on higher horsepower X9's. Claas and Fendt already have machines that are rated at 790, so it makes sense for Case IH, New Holland, and John Deere to approach that type of rating, or perhaps surpass it. Exciting times for a combine loving man! LolololAny more pictures of the case IH dealership show in europe.? Is there a new cab for the new next gen case IH dual axial flow combine. Looks as though case will be making a giant like new Holland with the 11.90
